Case 730 stuck in neutral- can't move shift stick. Ideas?
bicase
Hello all-
I just picked up a 730 comfort king with dual range transmission. It is in neutral and rolls freely. The shift stick doesn't move any way you try. It is stuck in the center. Guy I bought it from said he was driving it one day, another guy got on to drive it and jammed it like this. I'm just wondering what you may think the issue is before I dive in. Thanks much for your ideas.
I did that with my 830. Still not sure how, but the shiter came out of the rails. Took the shifter out, and a good flash light to see to line up the rails was a 15 minute
deal the second day. The first try I fought with it for 4 hours.
not sure why that likes to happen , my early 730 E H pulled that stunt a couple times, it is a double hand shaker shifters,. little bit of vigglin and all was well ,.. I think some slik 50 or lucas tranny lube mite help ,,. one fall my 800disel did not shift from 6th gear rite , shifter went into the double neutral slot and it was hung between gears and the shifter would not move a bit ., I was able to pull it in position to run the auger . chocked the inch pedal down and run the auger filling the bin , . after that was done , my nephew climbed on the 800 tractor and the shifter was acting like it was supposed to again,, never happened again .
