Case 630 COM Filter
RJKeith
I needed an intake manifold gasket for my 630, so I asked the dealer to add a COM filter to the order as well. I had looked online and couldn't find it, and the dealer couldn't find the number on his computer either. This is the filter that mounts in front of the radiator. Any suggestions?
It's in the 630 Book, but I think the Element Tom has pictured is the wrong Element for your 630. Unless your 630 has been changed over, the correct Element for your 630 is the G13113. We stock them both, as well as the O Ring.
thanks John for explaining that,,, I had it typed out but thought that just may confuse even more,, you can use either element if you change out the tin part on the housing cap,,, I change mine over to the later style
cnt
