70 Series Remotes
4020_guy
Should the remote control valve levers be spring loaded, self cancelling? Is 1600 psi the maximum pressure and can it be increased a bit? Used to JD, quite a learning curve. Thanks in advance.....Ron
Yes they should return to neutral when the cylinder "bottoms" depending on what model you have the max psi is 1750-2100 psi, and yes it can be increased,, but valve removal is necessary
cnt
