What exactly do I have here?
123456789
New User
Hi, new to forum.
I've had this tractor for decades, not entirely sure exactly what it is. VAC? Which model? Has eagle hitch, WFE with tube axle. It runs, but I need to fix the fuel tank. There are small parts here and there that need replaced, but most importantly the cast iron part that supports the dash. I plan on doing a total restore on this and take it to shows and maybe do some cultivating. I have the side mount cultivators with the 3pt on rear too, as well as a two bottom case plow.
Looks like a '51 or newer VAC-13. I had a '53 VAC-13 with a shifter stick like yours but I believe it was swapped off a VAC-14.
Joe
Joe, I see the steering wheel is shorter and the pedals only make it to the top of the transmission. I think that would make it a VAC-14 and
the shifter would be correct.
Looking through the wheel opening I think you're right Conner VAC-14. Upside down picture confused me, not that I am that hard to confuse.
Joe
Can anyone tell me what part(s) I'm missing for the throttle lever?
Also, the seat is bottomed out. I'm guessing it's from the rubber pucks under it. Are these parts still available?
(quoted from post at 16:35:14 07/16/16) Can anyone tell me what part(s) I'm missing for the throttle lever?
Also, where does the part in pic 3 go?
Pictures
