A little background. My Great Uncle purchased a Case 311B in 1958, when he passed away it went to my uncle. This little tractor is the first piece of motorized piece of equipment I learned how to drive. Spent many hours raking hay and doing chores around my uncle's farm. Fast forward, my uncle passed away last fall. My Aunt has been gracious enough to let me have the tractor. I got it home. Cleaned the dirt off of it and now am beginning the task of restoring the 311B. I have run into a couple issues from the beginning. While the tractor is a 6 volt positive ground unit. There is a 12 volt regulator on it which is causing me to scratch my head. Also in an attempt to get it to run. I have removed the wiring harness and reinstalled. One wire at a time. What has now become the China Syndrome. Everytime I go to start the unit. I end up firing the wire between the amp meter and the starter solenoid. I'm not an expert mechanic, so look for more questions from me as time goes on.
Thank you
Bobby
Thank you
Bobby
