VACLee- throttle rod length
dacaseguy
Lee, I checked the throttle rod length. With throttle lever in full throttle position and the rod unhooked from the Carb lever looks pretty close on length. I left the rod unhooked and started the VAC, it wants to go right to full throttle. I have to hold the throttle arm back in idle position. If I let go it goes right to full throttle. Is that correct? Dick
With rod unhooked from the carburetor it could pull the butterfly open. As I understand it you can manually push it back to a decent idle speed, correct. Call me sometime tomorrow. I am 3 hrs ahead of you time wise (NC). 336 516 4071. Lee
