I have just got a late D C eagle hitch Could someone tell me how much Gear oil the trans. and diff. hold ? I drained about 5 gallon of water out not much grease also Where do you check it ? Thanks Jim
here you go
cnt
The late model DCs with both brake pedals on the right side have 2 transmission drain plugs. The brake cross over shaft required a hump in the bottom of the transmission case. One drain in front of the brake cross over shaft and one behind the brake cross over shaft.
