1929 case L clutch adjustment
crl800
Can anyone help me with clutch adjustment procedure? It won't hold when under load. Thank you in advance. Carl.
I have a "L" ops until I can get some shots from it,, remove the side cover I do the left side as the belt pulley is not there,,, I made a "L" rod that will push in the lock pin and then you rotate the adjusting collar,, it should turn until the lock clicks back out one or two clicks should do it,, not sure right or left threads move it one or two clicks then check lever snap in,, thinking about 45-50 pounds pull to snap it in if you are pulling it
cnt
