Was able to finish the 1370 after a couple weeks of farm related chores. Items that were replaced in the rearend of this tractor include ring and pinion plus brgs. Entire differential housing and all parts contained within except a few diff lock plates. Both final drive sun gears and all six planetary gears. All brake disc,s. Rockshaft bushings and piston seals. Parking brake band. The power shift was in pretty good shape, received some brgs and seals. Did up grade to 1/2 in. bolts in the C2-C3 clutch pack. Tractor runs great and will get a cab kit and cleanup. Should be a good tractor now after almost ending up in the salvage yard. Rod.
