Case 500 fuel filters
Burl C
I'm changing the fuel filters on my Case 500 and have run in to a dead end on finding the second stage fuel filter, part 010013AB. My local dealer says they aren't available. So does anyone know if there is an aftermarket replacement? Or should I just worry about making sure the first and third filter are clean? Didn't check on availability of the first filter. Should have. Are they available?
Oh yeah, neglected taking care of my seldom used tractor fuel(biodiesel) over winter. Will never do that again, what a mess!
the 53 wheatland diesel? I got all filters for fuel at our local carquest parts store. if that tractor wasn't at the far farm id get you the carquest numbers.wix might as well
CASE still furnishes the 2nd stage filter, we stock them. However, nothing for the 1st stage is available. That is a washable, re-useable Brass element. If it ever becomes unuseable, simply remove the element, & that canister becomes a giant sediment bowl, removing water & particles. No worries because nothing will ever get by the 3rd stage.
Here is what I did with mine, I kept all of the original parts, but I like this setup for ease of service and bleeding, still have vacuum gauge and fuel press gauges plumbed in.
Ben
I'll give you call tomorrow, John. I liked the filter setup on ben's tractor. Nice and neat, but would rather keep mine original as possible.
I read where the 500 was supposed to be desert tan and flambu red.my 2 are both like yours originally but were painted tan and red.yours looks nice too
The 500 came out in 1953. Flambeau was the only color.....desert sunset came with the next generation of tractors. The 600 was the upgrade of the 500 and was desert sunset and flambeau.
The third stage on my 500 is a Wix 33191 if it helps any. I dont yet know the numbers of the first and second stage.
