york
- Location
- Mechanicsville Va
I will start with my first problem. #4 plug had no compression, I found rocker arm broken. Replaced rocker arm now I have good compression. But now the spark plug is saturated with oil and fails to fire. I know oil could be coming from broken cylinder oil ring or it could be coming from a worn valve seal. I don't understand what caused a broken rocker arm in the first place, no bent push rod, valve opens and closes just fine. But could the broken rocker arm indicate a valve condition causing oil to enter the cylinder. Any way to determine cause of oil saturating the plug. Plug fires just fine out of the head.
