widefront tell me about your dc
wilson ind
I have the virtual twin to your DC. I have the notched front weight. Mine was located in Wyoming sugare beet country. Where on
earth did you find yours. do you have the heavy front wheels? I never could find the pto eagle hitch cover. had to make a heavy
one for over the top of pto
Got got that DC from Youngstown Ohio about 10 years ago. I was fortunate that that front end weight was on it. The serial number stamped in block housing has an Al after it, aluminum Pistons I'm told.
Installed a set of 25 tooth sprockets out of DI. Runs 21 mph and has great power. After market pto covers (3 point) are readily available. I'm near I80/I35 jct. Stop in
Your front hubs have both the 3 and the 5 bolt hole pattern? Could you please let me know the casting number on those hubs if you get a chance?
Thanks'
Beagle
Good eye. Here is the part number
