830 c.k. com hydraulics
I know this has been discussed before but I got a new to me mower.The question is will it run one-way hydraulics? The new mower is case international,one way cylinder to lift two way to swing the hitch.Seems like I have to change something but I can't remember.thanks Big Sal
They work just fine, but if you move the lever to full down it will dead head the circuit and oil will have to escape past the pressure relief. On the 870 that I have on my MoCo I have an oil return coupler that dumps oil to the rear end of the tractor. I have made a hose that plugs into the other side of the valve and the dump coupler so oil flows back to the reservoir when the valve is pulled to the full lower position.
I run my Case/IH (more IH than Case) 1190 mower/condtioner with my 830CK and it works just fine. Top left and right remotes swing the tongue, the lower left remote lifts the header. It drops back just fine, with no mods. It will not if hooked to the right side, however.
