interdeere
New User
Hey I've got a 2290 case with a dead hydraulic system. Come to find out I'm not getting oil to filter housing. I split tractor to check pumps, shafts, sheared keys and found no major problems. I've been told the charge pump supplies oil to filters and the pump looked fine so what else can be wrong? Case dealership is of no help at all and one mechanic says it may have a internal crack or hole in rearend housing. Any ideas? Thanks
Did you check the bevel gears that drive the pumps? That can all be done without splitting the engine from the transmission.
