Just making sure....
GG1170
I'm going to replace the hydraulic oil & filter in my Case 1070 (8-speed). I have several pails of 303, is this oil ok to use or do I purchase Hy-tran. Thanks
Honestly; I would buy HyTran. I found out the hard way what happens when you dont use Hytran. I used Marathon 577 in a Cherry 1370 and about ruined the tractor. I know your tractor is an 8 speed but if it had Hytran in it before then I strongly suggest you use Hytran again.
303 may cause seal leaks. Hytran has an additive to control leaks. Hytran protects hydraulics 303 does not.
