1970 Case 770 Agri King without Power Shift
MAH
Hello, I have had this tractor for almost a year. I have had a few minor issues but have worked through them. Recently, I have started having problems with brakes. At first, I had to pump them up to get them to work and now I can pump them and no brakes at all. Do they need bleeding or is there something else I should try? The parking brake works perfect. So, I am thinking the my brake issue may be a minor one I just need some insight.
Okay, I will check mastercylinder. I seen the previous post about the powershift. I wanted to make sure I could do the same for mine. Thanks for your help.
