Fuel pump for Stationary Case engine
Farmallb
Ive got a 4cyl air cooled engine setting crossways on my 140W Case hay bailer. It had a funny looking fuel pump on it. it had the glass bowl above the rest of it. It had an arm that came out of it and went into the engine. That arm pumped the fuel. Anybody know where I can get one. Im using an electric fuel inline pump with more or less satisfactory results. id like to replace it with what actually goes on the engine.
If you use an electric fuel pump make sure its one with low pressure just a couple of lbs. and low volume.
Over the counter electric pumps will be around 6# pressure, that will overpower the float system, be sure and check the pressure, preferably with a T rigged into the line. If the pressure is in the 2 1/2 to 3# range your system is good to go. Of course the volume has to be there too. Be sure your "device" is a true pressure regulator and not a restricter.....
Does it look similar to this. Case # G10052 crosses to AC # 1539832. Was used on early 50s Chevrolet.
