Hello this is my first post on a tractor forum I recently purchased a Case 580ck with the backhoe removed. It is definitely a project but I did manage to get it running pretty well and the hydraulics also seem to work well while in motion but once I let the control valves go to neutral(I'm really only having a problem with the loader up and down valve)the motor will bog and die as if it is still under load. Almost like the valve is not centered correctly for neutral.the motor is the gas g159. As you guys know this machine has the governor setup that can be an issue at times. Mine does seem to work as the rpm's rise while lifting bucket. if anyone could point me in the right direction on my hydraulic issue it would' be much appreciated. Thanks Matt
