Hi everyone need help here, need some pics and instructions on case 930, a 1964 with serial #8250496, this tractor has the hyd. pump below the pto shaft not above, (have 3 different manauls but all show the hyd.pump above pto shaft, the problem i have is it just stopped working everything checks out good but no out put to brake away hyd. couplings, it was never low are hot and not ever low, the past owner did put in hyd. fluid that is not what it calls for I was thinking this mite have clogged something up but would like the pics on where everything is on this model, with the hyd pump under the pto shaft.
