Jeremy McNary
I have a 2290 that has recently developed an Issue, when you push the Inching pedal down it doesn't do its surge like it should, I hooked up a set of guages to it and in low c4 reads zero however in reverse it reads 190. Service manual states that this probably means the .028 orfice in the valve block is plugged. My question is were exactly in the valve block is this orfice and is it going to require removal of the block from the tractor to clean it out? Local dealer doesn't keep gaskets for these on hand and I kind of need to get back to the field with it as its my only loader tractor at the moment and I have about 600 round bales sitting in my alfalfa field that I need to get off.
