I am going this evening to look at a Case 530. I will be using the machine for general loader work around the house, food plotting and small "farming" (couple acres/hobby), and jack pine tree work. Any opinions on this machine? Anything I should look for? I do know it has transmission PTO so I will get an overrun and slip clutch. It would appear most parts can be found but are somewhat limited and expensive.
For comparison, I am also looking at a Ford 641. The Ford is about a thousand pounds lighter with 3 more hp. I am leaning more towards the Case at this point because it is heavier with a better loader. Also has power steering. Both are priced about the same.
Any input is appreciated.
