vac pictures
s,mac
I bought this VAC wide front last November. Finally got it running today. Had to replace the gas tank rebuild the carb and unstick one valve. Now it runs very well. Steve
You will have it looking like new in no time. When I bought mine only one wheel turned, cover was off the trans., (busted gear) and the engine was stuck. It has plowed, ground corn and raked hay since the rebuild. Mine is a 48.
Glad you got it running Steve. I'm making headway on my VAC. Will be putting front tire on today, installing the head after new valve job and install new guages today. Don't forget our Fathers day show at Pottsville if you can make it. Dick
