Track chain for 310?
jon f mn
Anyone have or know where I can get a track chain for my 310 crawler? Going to need a chain and some rollers. Any leads you could pass on would be appreciated.
Try the track shop at RDO EQ. in Burnsville, Mn. There is considerable interchange on undercarriage and they may be able to help. I used to work for RDO industrial in Aberdeen and worked with the track shop on a lot of stuff.
When I bought mine it had Cat tracks on it. Previous owner said they were the same pitch as Case. Not so! Found used tracks for $1500......not worth it. So I have a torn apart 310 with bad sprockets and Cat tracks.....mine is a loader crawler with the eyebrow front cowl.
Might try Schaefer's in Wolf Lake Il. I bought the bull gear for my 310 from them. Easy to work with
Are your rails bad, or just the pins and bushings? I installed new pins and bushings in my D2 citrus tractor for less money than a new pair of tires.
I will have to look again, but I don't think mine has bushings. I think the worn through part is part of the link. If they have bushings then just bushings would likely do it since the rest of the link looked ok.
