830 case diesel need help
rickeyo
New User
trying to figure out what my gear scheme is. it's an 830 with 1 8 spd shifter. trying to find my highest gear so I can jack up one wheel and break the engine loose by turning it backwards, after soaking the cylinders in ATF I guess through the injector holes? new rebuilt starter, hot batteries, locked up engine. clean oil no milkyness or water in it, maybe hydrolocked but don't know with what, or how should I go about breaking this ol girl loose?
(quoted from post at 21:09:46 05/31/16) Did you try loosening the starter? Possibly you just have a stuck starter. Don
sorry forgot to mention I have already had the starter professionally rebuilt by a starter and alternator shop. it barley moved now it cranks out some good rpms with a hot battery, but still not enough to turn that big heavy seized up block over.
also can't even budge it with a huge wrench and cheater pipe on end of the crankshaft after I took out the radiator and front sheet metal to get to it
