BROKE FUEL BOWL 504 TD
NIK OWEN
GUESS I GOT HER TITE ENOUGH 2 STOP DRIP...SHE FRACTURED...WHERE CAN I FIND ONE? SHE WUZ 2 3/4 DIA, 4 IN HI...ON FINE CASE 1450 DOZER, L. SIDE...ALSO, ALL FUEL LINES DRIP...HAVE A RUBBER GROMMET @ EACH JOINT...WHERE DO I GET NEW ONES? THANX FOR ALL HELP, BE BLESSED, GRATEFUL, PREPARED, VIET VET AGE 74
That's a tough one!! The 1450 Dozer uses a different strainer assembly than the 504 AG Engines. CASE does not list the Bowl by itself. Subs to 361798A1 Strainer Assembly-$287.85. The outside Dia. of the Ag Bowl is 1-3/8".
I removed mine from my early 1070 ,.the system is gravity feed ,and appears to me to depend on injector pump suction ,,. kept getting air in the fuel , been putting up with this ever since the 1070 limpt up the drive begging for help an some luvin... I keep a bicycle hand pump and hose in the 1070 to blow out the fuel valve ,.. am about to put another set of filters on the big boy , I just installed a 1 inch plastic stand line in there to stay above the dirt ,. I suspect there is floating trash in the tank ,. but it never showed up in the sediment bowl, if it is knoked off next time I pull the valve I WILL PULL THE TANK AND GIVE IRT AGGOD CLEANIN . I am taking chemo now dont feel worthachit , but one of the things I wanted to do was pull the tank and perhaps instal a electric fuel lift pump , used to have all sorts of young helpin hands around here for such jobs , they learned by doing,. now they got busnez of their own and a full day planned every day for money making ,.. I aint complaining ,. I am rather proud to have been a part of their trainINg to be responsible adults . rite now I choose my battles , and get by ok ,.
