I've got a Case 2294 12 speed powershift
that out of the blue quiet moving, one
moment i was mowing hay and then i shut it
off to put fuel in it and then went to
restart and it would simply not move. No
surging of the engine when putting in the
clutch as with all case powershifts tractors
do that I've owned and operated, I had a
respectable old time case dealer come out
and they got it to move and told me it was a
electrical short and that they had replaced
the circuit board under the shifting counsel
with a used one, however this was not the
problem and even after replacing it, they
did show me while I was there that it was a
electrical problem by using a tool that I am
not familiar with that while attached to the
rely wire in dash they could shift the gears
with it, you could hear the engine surge
just like it always does and the tractor
would go through the gears normally although
not moving you could clearly hear it go into
gear like it would do normally, however i
was not able to stay with them through the
rest of the repair so a couple hours later
they called and said it was a electrical
wire problem and the tractor was good to go,
but a couple weeks after i was going down
the road and went to a stop sign and it did
the same exact thing when going to take off
it would not move. I have switched the
relays around inside the dash and this did
not help, so I bought a new range switch
sence the old one was cracked, I hooked it
up and it still will not move, got looking
at the wiring diagram and it says there
should be a 9th terminal on the switch for a
blue and white wire running off the circuit
board to the switch the problem is my switch
only has 8, do I have the wrong switch?
Hopefully these pics of the diagram will
help, thanks for any help
