52 dc brakes
caseydog
My 52 DC needs the brakes adjusted or replaced. How big of a job is it and more important what does it entail? The books I have cover brakes for earlier serial numbers than mine.
There pretty simple to adjust simply jack up the tractor and tighten the nut until you feel drag then back off 3/4 turn then do the other wheel. I can send you the information you need on it should you decide you want to change the brake disks it covers the info on the governor adjustment inspection and replacement as well for the early and late model DC 56000 and up. Email should be open
Brake discs are some times hard to remove. The lining wears out and the disc slides further in on the splined shaft. It slides up against where the splines end on the shaft a wedges there.
When you reply. Up at the top under your user name. You need to add your email address. Then members can email you direct.
