Anyone ever try to get parts for a 281 side delivery rake?
Camozzi04
Its a righthanded rake. Im looking for the pawl housing on the right side. Also need new dogs i believe is what they are called that go inside the housing. Any suggestions?thanks.
call john saeli ,, he will have teeth for sure and perhaps a lead for the part ,, fry equipment in penn state mite have used parts , or mite know where to find them,..good luck
I finally bought a couple of parts rakes to work on the restoration of mine. I use it for all my smaller areas, it gives the SC some legimacy once in while. I try to limit what I drag home or have to actually being useful on the farm, doesn't help to much but it sounds good to my wife. Are you talking about the drive pawls or dogs in the hubs? I've swapped/traded some of the parts off my spare rakes, but drop a line and I'll see if I have anything useful
(quoted from post at 06:02:44 05/25/16) I finally bought a couple of parts rakes to work on the restoration of mine. I use it for all my smaller areas, it gives the SC some legimacy once in while. I try to limit what I drag home or have to actually being useful on the farm, doesn't help to much but it sounds good to my wife. Are you talking about the drive pawls or dogs in the hubs? I've swapped/traded some of the parts off my spare rakes, but drop a line and I'll see if I have anything useful
Life grabbed me momentarily. Ill try to narrow down the exact parts this weekend. I retrieved a couple casting #'s as well. Your lucky to find a spare parts rake. Ive never even seen another 281 in California. Mostly New holland,international,john deere. I do like how wide the rake is,along with its heavy construction. I dont wanna part with it. I see what i can dig up this weekend. Thanks for posting.
one of the casting #'s is T1510. Its the little clicky mechanism that plugs in with a dowl and rides around and locks inside the axle pawl? I do need that guy.
i have a case rake left hand discharge its a side delivery with hyd. lift i got it for free because the part i think your talking about was broke couldnt find one any where but meyers salvage in aberdeen had the hole assembly for a 258 nh milled my shaft down and put the nh one on works just fine not orignal but it works.
loren
(quoted from post at 21:09:12 05/27/16) i have a case rake left hand discharge its a side delivery with hyd. lift i got it for free because the part i think your talking about was broke couldnt find one any where but meyers salvage in aberdeen had the hole assembly for a 258 nh milled my shaft down and put the nh one on works just fine not orignal but it works.
loren
Thats great information to hear. I put the hydraulic cylinder on mine. Also the correct size tires 6.70x15. Thanks for the input.
