Case VAC 4 point vent leakage
Fearless02
New User
I have been using my Case VAC for over 40 years now (just use it for spraying weeds - 70 gal boom sprayer). The last 10 years it has been leaking oil out the vent cap just forward of the foot peddles. I add oil through the fill up plug, but when I use the 3 point (going up or down) I get oil leakage coming out the vent cap.
Anyone have solution(s) for me to get this leak to stop?
Thanks.
the piston seal in the Eagle Hitch rockshaft is bad,, not a bad fix remove the bolts holding the rockshaft piston housing to get to the piston,, make sure you lower the arms fully first
the link shows the piston and parts, if you hit the "back" button on the link it should take you to the previous page that shows the piston cover
cnt
rockshaft parts page
