David Brown 880 Flywheel
rustyal
How do you remove the dual stage flywheel. Got the pressure plate
and one disc out. But don't see what's holding the rest on.
The "separator plate" may be stuck, but its really not held in there by anything but a tight fit. From your description, that is what I'm guessing the problem is. Spray kroil / wd-40 / other lubricant on all the teeth at the edges and work loose?
Once you get separator plate out, watch for the three springs.
Study the factory manual. There's a free pdf version. Go to this google site and look for the manual "David brown 770-1412 Service Manual". Click on that one and then go to chapter on "Clutch Selectamatic tractors". Good luck.
https://sites.google.com/site/deerebrown/david-brown-info-ii
