Hey all, I have a problem with my 700 case's transmission. I've had the cover off but don't see anything that jumps out at me.
When I have it in eighth gear going down the road, the tractor will start to slow down. so I pull over and try to shift into a different gear and the shifter is locked up and won't move. Didn't need 8th gear for anything so I didn't worry about it. Started to make noise in 6th gear now. Still don't see anything obvious with the cover off.
After setting for a minute or so everything works fine again.
Thanks in advance
Thanks in advance
