930 CK leaking oil at injector pump
OLD 10-20
New User
I have a CASE 930 comfort king western special . My problem is the Bosch fuel injector pump leaks motor oil at the front and at the rear where the throttle shaft ? comes out the housing . Is there a rubber o ring or a oil seal that could be bad ? Same at the front where it is connected . There maybe a bad gasket ? I loose more motor oil this way than what is normally used by the engine . Any simple fix or remove and take to a repair shop ?
