Help with 1070 hydraulic remotes
I need to use my 1070 I bought this past winter and the hydraulic remotes dont work, I tried both sets and neither work. It will move the cylinder about a inch either way and then you hear the hydraulic pump like its under load or bottomed the cylinder out. I though it was bad hoses so I replaced them and it still does it. I hook it up to a different tractor and it raises and lowers perfect. Any idea? I really need this going so any help is appreciated.
do you have both top hooked up? one on the left and one on the right is a pair
the ones on the bottom, same, one bottom left and one bottom right is a pair
No, hooked up just one side but I just now was wondering that. If I move one lever forward and one back then it works. Thats a easy fix. Thanks for the help.
