I just had to replace a burst hose that runs to the bottom of the radiator and to the hydraulic pump. Believe this was a hydraulic line and now need to know where to fill hydraulic fluid. I have also been reading about gear oil for the rear end. The tractor has one shifter for the hi and low range (8 forward gears and 2 Reverse gears). Has one large breather/dipstick on the left side of the tractor and a pipe plug above the PTO. Where would be the best place to fill and check each of these fluids ?
I'm pretty sure all of the hydraulic fluid is now gone when the hose to the radiator burst. Serial # is attached.
[/img]
[/img]
