farmerbob02
I have a question on an issue with the auxiliary lighting on a case 1070. The previous owner has connected auxiliary flood lights on the front and back of the tractor for baling and now after making changes on the battery arrangement (going from one battery to two in series), the connector on the battery end of the power wire that runs from the battery to the switch on the set of lights on the aftermarket switch gets hot after it is hooked up for a short time. The other set that is connected into the factory rotary switch works with no apparent issues. Is it a ground issue or is the wire too small to support the lights connected to it? Shouldn't be, but is it too much now with the two batteries in series? If it can't be connected directly to the battery, where would be a good spot to get factory power? Help is greatly appreciated.
