Sc needle and seat
tractorguy2
Anyone know where I can buy just the needle and seat for a Zenith 9667 carb on my 48 SC?
I put a kit in it two years ago. The needle won't seal anymore.
It would not be cost effective to just sell a seat and needle. Go Big and buy a kit .they come in 3 kit groups. John Saeli can make you whole.
I found it online. needle and seat $5.95, gasket .72, new float $16.95 order qualifies free shipping. Cheaper than a kit and I get a float.
don't get too hepped up on Viton needles, they often leak worse than the metal ones, as far as "going big" and buying a kit if the carb just needs to be cleaned I often just make a new gasket and if the needle looks (and worked good) I often reuse them, carb kits are the biggest rip off there is, there isn't $3.00 worth of parts in a $30.00 kit
The old needle and the new one are both bit on tips. The problem with my old needle is the point is longer in the center.
I priced kits at both Carquest and NAPA.each wants around $65.
$65.00? That's nuts. I bought a kit for a 300 from a person on this site and the hole for the throttle arm was drilled in the wrong spot so you couldn't get the butterfly into the carb so I had to use the old one over which had a little wear and thus was the reason for buying a kit with a shaft in the first place, kits are the biggest screw job ever
