3594 laboring in 5th
Working on a 3594 with 24 speed power shift. When you get to 5th on the power shift the tractor laborers like your under extreme load. Keeps moving and everything. All other gears work as they should. Anyone experence this before?
sounds like one set of clutch packs is not releasing when you go to the fifth powershift, I suggest you get it diagnosed quickly as any time spent using it that way will warp plates in the powershift and require an expensive rebuild, until you can get it in to work on it avoid the 5th powershift....
