Case 1070 front end bearings need replacing
elkcagg
How would you replace bearings in a front end on a Case 1070? Jack entire front end up to clear spindles from knee or remove the entire front end assembly? Thanks
Jack the front end up enough to clear the spindles and put a floor jack under the spindle to slowly let down they have a lil weight to them with the hubs on.
