1070 hydraulic hose
I need a hydraulic line for a 1070 ps tractor. I can't seem to find the line on any parts break downs nor have the parts associates over the phone been able to locate it. It is the line from the pump to thefilter, on the power shift side. metalon the ends for a whilethen rubber in the middle. Any ideas? Any good case parts guys chime it?
If its the rubber hose that is bad.Our hydraulic repair shop[Kelly's supply]makes up a new hose with a compression end to go onto the steel pipe after you cut the hose off. Been working just fine so far.
Well, that picture has no power shift filter nor line. I will ask around for a repair, but have been shut down in the past. That drawing seems to have everything but the power shift filter and the line feeding it, which is what I need. Thanks.
You asked for the line from the PUMP to the filter,,, the line runs from the PUMP to the FLOW DIVIDER Then to the filter AND that is what the link takes you too, if you bother to look at the extra diagrams on the link it shows there is several different lines from the PUMP to the FLOW DIVEDER, depending on your serial#, there are two filters on the PS units one for the PS the other for the power steering and brake system, the filter in the link I posted you Is the power shift filter like you asked for
The line I need is found in the parts diagrams under steering and brakes. It is not any of the pictures yousent links to nor is it in any of the pictures, and the power shift tractors are the only one that used this line, and also this line has no affiliation with the flow divider. Thanks.
I found a line/hose, it is $$$$$$ so I was looking for an alternative, see if we can build one, repair this one, or find one somewhere that is discounted, old stock, ordered wrong part, salvaged, what ever. I am not crazy about a used hose, but it might be worth a try. thanks for all the help.
