Rear wheel weights: VAC vs DC vs D
Mathias NY
I am in the process of acquiring a VAC and wondering if wheel weights can be adapted from the larger tractors. Does anyone know if the bolt patterns are similar?
I also have a set of weights from an Allis B that I don't need any more (I'm trading the tractor for the VAC). Would these weights fit the VAC?
Thanks for the feedback.
If you can match the bolt pattern you could put bi9gger weights on the VAC. I have a VAC with 250-300 Lb weights. They were on it when I bought it. If you look at my post a couple post back I posted pictues. Dick
It can be done. However spacers will need to be made. Here is what we made for the DC weight that was temporarily on my VAC.
Tim - I'm in Wayne County, about half way between Rochester and Syracuse. I also have a set of wishbone weights for the B to get rid of. Send me an email if you are interested.
Thanks for the replies. If I can't come up with a set of VAC weights, I'll see if I can make some brackets to hold my DC weights.
