Adirondack case guy
I fabed up a pair of front fenders for my 931 today. I have a plan in my head to build a RH and LH mounting frames to bolt onto the top of the spindles utilizing the big spindle nut, and a bracket to the front of each tierod arm useing the nut on the ball joint to secure it to my fender bracket. There are some differences between the RH steering arm with the draglink arm on the rear and the LH without the rear arm.
Do you have any detailed pics of the fenders on your 1031 that show the mounting brackets.
I'm planning on fabing a step on the rear of each fender so this 220# Case guy can step up and reach the radiator cap. I laided down a peice of aluminum dimomd plate to illistrate the step at the rear of each fender.
Loren
Loren
