Case 510B hydraulic control levers
9NDan(CA)
New User
Hi,
I have a 1959 Case 510B. The inner hydraulic control lever is for raising /lowering the 3 point hitch, what is the outer lever for? It is stuck, I am letting some penetrating oil sit on the linkage for a few days to see if I can get it loose.
Thanks
Look up under your gas tank at the control valves that your levers are operating. The lower control valve is generally used for single acting cylinders like the 3. hitch. The upper control valve is generally setup to operate double acting cylinders like one connect to the remotes. Either control valve can be used for SA or DA simply by installing or removing a pipe plug in the center port of the interlock block assembly that is bolted to the side of the control valve.
Joe
