energy cell removal
Olie
Any ideas how to remove the energy cell form the head of a Case diesel tractor. Ive tried tapping from behind with a rod,using a screw from the front and nothing seams to work.
Do you have the heads on a bench, If so place a 1/2 inch ball in the tapered opening and a good heavy punch and hammer, drive on the ball, it'll go, done dozens that way, the ball will protect the opening.
I need to remember that tip. I have also heated the area around the cell area. On heads that were total junk, I've cut them out.
