1370 started having this weird rotational pulsation or surge not sure how to describe, it feels like if you would have knots on the back tires. When you let up the clutch it feels different than it should feels like theres slack in the drive line. As soon as tractor moves pulsation starts. I dont
think its coming from engine the rpms stay steady. Does this in any gear or range and reverse. It just pulses faster or slower depending on gear/range. It shifts fine. I was pulling a field cultivator 1500 rpm , 2nd gear 3rd range and shifting to 2nd range to turn around. It was pulling
with no problem at all like it always does except for this weird pulse which wasnt quite as noticeable when pulling. Then it started making loud banging noises from under the seat/cab in the area of the diff. I think ,hard to tell while driving. I stopped and unhooked the cultivator and
now I cant reproduce the noise but the pulsation is still there and seems worse when nothing is hooked up. Everything else works ok. Anybody else ever experienced any thing like this.
