1175 case original issue was pto would not stop. Removed
housing and replaced cluch pack brake pad is good.
Reassembled and op checked still not shutting off.
Disconnected cable and I can make it stop sometimes/
sometimes it won't, also varies with rpm will hold at idle but
most times will start around 1200rpm, seems like an issue
with the flow divider? Where do I start? Thanks
