Since we are on the subject of 430 hydraulics I will pose another problem. I am having trouble with the 3 pt on my 430 draft-o-matic. There is a 5-6 second delay when you move the lift lever to the raise position until it responds. Lowers fine with no delay. Engine speed does not affect the delay time. Once it starts to raise it comes up at normal speed and is smooth without any jerking. The lift capacity has not been affected either. The remotes work fine with no delay. Can pull them during the delay and it loads the engine with the normal squeal you hear when they are deadheading. Fluid level is fine, and will easily hold an elevated load overnight. No other apparent problem other than the delay which makes it very aggravating to use with ground engaging equipment. Have not checked pressure due to the ease at which it lifts a heavy load once it starts up. Not being sure what the throttling valve actually does, did try adjusting it but that had no affect. What ever the cause is, it just showed up immediately in use this spring. Was working fine last fall when the 3 pt was last used. All linkage is in good working order. Will welcome any suggestions as to where to start. Lee
