I have a 1370 that seems to be slightly low on hydraulic pressure. I have a top air sprayer I need to pull with it and it won't fold the booms up and it will barley fold up the wings on my 1175 kewanee disk. You can hear the motor load up and it squeals and makes noise just like when a cylinder reaches the end of its stroke. I stuck a gauge in the remote plug and it showed about 1750 psi. I have a 995 david brown which will fold both implements with no problem and I checked it with the same gauge and it read 2500 psi. Do I have a weak pump or is my relief valve opening too early? Or is it a completely different problem I'm missing all together. Any suggestions from you seasoned case vets would be very much appreciated. Thanks for reading my post.
