Got to do some of Rods 504 work
560farm
Location
NEIL
Turns out Rod isn't alone on all his recent 504 work, lol :) Luckily I was only changing 6 valve cover gaskets on the 20 & 23, not tearing down for major work or overhauling like he has been lately. The 20 was easy, the 23 not so much with having to remove/move things to get to the center cover. It's still to cold and wet here in NEIL to do any field work and these leaks needed to be fixed.
Brad
Brad: I'm impressed w/ how clean everything is under the Valve Cover. Would you tell us your favorite brand of oil?
John, we have always used Cen-pe-co in the engines and CIH Hy-Tran in PS. All the older Case and IH/Farmall stuff still gets straight 30wt and the newer CIH tractors and combine get 15w-40 as that's what is called for in them. All the gassers no matter what color get CIH low ash straight 30wt.
Brad
