Case VAC water pump pulley question
oldtymer
We have a VAC that needs a water pump pulley. The old one has a thick base and tapped holes that matches with slots on the outer piece that are used to adjust belt tension. When looking on Ebay I found 2 that are listed for the VAC but they don't have the slots and stuff on the adjustment. Did they change the design at some time and will they interchange?
I did not know they used that style on a VAC. Both the VAC's we have use the solid pulley and generator adjustment to tighten the fan belt. Rod.
I had one with no generator, and the adjustable pulley, which was the only way to tighten the belt without a generator.
So if it has a generator I can use the solid one... I have found a few of those but no adjustable ones.. Thanks!
