VAC Hydraulics
Steve Heiken
New User
I have a VAC the hydraulics are foaming bad . I have drained the tube several times thinking it was water with no luck . was wondering if there is somewhere else to drain or what else I could do to fix this Thanks
if you have water ,. a red bottle of heet will get it to all come out ,,. you simply need todrain all plugs to the lowest point ..
(quoted from post at 10:59:30 04/12/16) Steve: What are you using for oil?
ydraulic fluid I just drained some in a can and I don't think it is water. When it settled out it was nice and clear just like when it went in. How do I find where it is getting the air?
Check the suction tube good for cracks/air leaks. It could be cracked where it goes into the torque tube or the pump.
